- Feb 19, 2020
- 116
- 12,563
First the you shouldn't easily turn the center spindle with the belt engaged as this mower has a full engagement of the deck at all times. If you can something is out of whack. I do realize there is less belt contact with the center spindle pulley but there still be considerable resistance. It may that the center pulley is loose on the spindle, not torqued to spec.
Another thing to try is slowing a little when moving through heavy giving the mower time to cut the grass. Got to give it time to cut and clear the deck.
Just pickup with one these mower so I really have got try it out on my own lawn but this what suspect as many mowers have problems with extra tall grass, even some the big commercial mowers. Even with it low hours I still had the ilder arm and one of the idler pulleys.
