- Feb 19, 2020
- Threads
- 116
- 12,613
Preload is the resistance to turning once the assembly is tighten and is usually measures in either in-lbs or ft-lbs depending the manufacture's designed specs. Usually you got to initial more to fully seat the cups, loosen, and retighten to the preload spec.
An example is one of the Polaris ATVs I repair where the front axle is initially torque to 400 in-lbs to fully seat the cone cups, then the nut is back off 3/4 of a turn, and finally re-torqued to a rolling torque (preload) of 150 in-lbs.
I don't currently have the preload spec but an email is in for it.
