PTmowerMech
- Apr 16, 2018
- 443
- 3,421
Looks like that carb has a purge bulb.
Be sure the fuel inlet side holds 7psi.
Then press and release the purge bulb. Pressure should drop slightly an hold each time you press bulb.
Apply 7 psi pressure to purge line barb. Should hold pressure. If those are good look for bad check valve or welch plug fallen out.
I need to do some research on check valves. I've never messed with them.
