PTmowerMech
- Apr 16, 2018
- 391
- 2,994
This thing is flooding like crazy. THE only way to keep it running is to shoot air in the venturee, constantly. Take the air away, and it floods. out.
Question: Is this solely a needle/Seat issue?
The gaskets and everything inside looks good. Metering leveler was spot on. It holds 7lbs
After cleaning it (not in the ultrasonic, which is broken) putting it all back together, pressure testing it and firing it up. It didn't flood like it was before. It'll start without pushing air thought it. But can't get it to idle for long. Not long enough change the low side. I removed the H so I could get it off what sounded like the strokin sound. Well, that worked except I was able to screw it in and it never got to the lean running sound.
Darn thing is giving me fits. I remember someone mentioning a H side that runs the same closed as open. But can't remember what they said about it.
