Alan46
- May 12, 2023
- 2
- 48
Open the pictures in any photo editing device that you like .
Resize the photo to 12" along the longest side then se the resolution to 72 DPI & file type to JPG
What most forget to do is now SAVE the image
It will now upload
Yes, place the 2 pieces back together & fit up another plate to size, place over the break, 1/2 on each side, clamp in place, drill a couple holes in each side & Bolt together.. Good grade bolts & locking nuts or Loc-Tite should be used.. 4 bolts would be plenty imo,.is there a fix besides welding?
Thanks so much 7394,Yes, place the 2 pieces back together & fit up another plate to size, place over the break, 1/2 on each side, clamp in place, drill a couple holes in each side & Bolt together.. Good grade bolts & locking nuts or Loc-Tite should be used.. 4 bolts would be plenty imo,.
The bolts should be snug thru the holes.
Thanks for the information!Whether you weld it or plate it you are going to have to take some stuff off in order to get to the break. In my opinion I don't think a one inch strip of metal on each side of the break would be enough. You would have to use some small bolts and I don't think they could handle the pounding of mowing. If it was mine I'd weld it but if I was going to plate it I would have 3-4 inches on each side and 3 or 4 bolts on each side
