tsgtwheeler
- May 1, 2018
- 2
I have a eco walk behind trimmer. It has a Brigs & straton 6.75 hp. model 799875. I ran it for a while and ran out of gas. I went in and ate some lunch. When I came back out and put in fresh fuel it will not start, but it seems to back fire out of the muffler. I have pulled the carb off and cleaned it with my ultra sonic cleaner. ( I use simple green in my cleaner). I dried the card and blew out all the passage ways. I also tool the flywheel off and the key is not sheared. I did a compression test and am getting about 95 psi in the cylinder. I have installed a new air filter and plug. I do not understand what could be going on. Any help would be appreciated.
Thanks
Thanks
