sdnomad
- Apr 19, 2023
- 8
Need help figuring out where my oil leak is coming from. Its coming from above the sump gasket so I don't believe its that. Its running down the fins of both heads and drips off the bottom of the heads near the exhaust ports. It's not the valve cover gaskets because I made sure they were sealed. The only thing I can think it might be is head gaskets. I looked over the sump gasket seam and it looks good and dry. Should I just start tearing off the heads? What else could it be?
