Briggs V Twin 22HP oil leak under both cylinder heads
Status
Not open for further replies.
Need help figuring out where my oil leak is coming from. Its coming from above the sump gasket so I don't believe its that. Its running down the fins of both heads and drips off the bottom of the heads near the exhaust ports. It's not the valve cover gaskets because I made sure they were sealed. The only thing I can think it might be is head gaskets. I looked over the sump gasket seam and it looks good and dry. Should I just start tearing off the heads? What else could it be?
Looks like an exhaust gasket is bad.
Have you checked the head to see if it is flat. It could be warped. Also check the block.
Status
