Mike88se
- Oct 11, 2013
- 739
Hey... the engineman up there said this is a 498965. That is a carb for a Briggs and Stratton 12F702-1814-E1 engine which is what we have here along with a throttle control that works and a primer system that doesn't. Nobody is you to pull any ******* teeth.Wow, a whole bunch of folks boldly stating the obvious!
How about putting up the correct model/serial/type numbers off of the mower and engine????????
Look under the plate that the throttle control is mounted for the mower's model/serial number!
You should know where the engines Model/Type/Code numbers are!!!!!
Damn!!! Why do we have to pull teeth on every thread????
