EngineMan
- Jun 12, 2012
- Threads
- 9
- 2,275
Ok... two questions.
What is that primer bulb looking thing where a primer bulb should be?
What controls the choke? Is there a part missing that fits on to of that cam looking thing that would connect to a spring or rod?
Ah hell 3 questions... if the carb is a 498965 then why does it have 214570 stamped on it?
Sure looks like a primer bulb to me.
Hell might as well ask another one
When the choke plate is closed the mower still won't start w/o gas or carb cleaner sprayed in the throat. How about just drilling that hole out?
answer 1 I don't see any "primer bulb looking thing"
answer 2 numbers on the carb are not the part number from the B&S parts manual.
answer 3 apart from damaging the carb, you be wasting your time drilling out anything, but good luck anyway..!
