Briggs & Stratton vertical shaft comparability with larger engine sizes
Fabian
  • / Briggs & Stratton vertical shaft comparability with larger engine sizes
What are the physical internal differences between the 8hp and the 12 hp engines?
Briggs did what most makes did.
Started with a bore & stroke for one series then either stroked or bored it go to the next series
Within a series they used various devices like a smaller carb, or smaller jets or a restrictive manifold to get the 1/2Hp incriments
The first number is a 6 digit number so your current engine is 091702 with the 09 being the displacement in cu in.
Usually within a single series there was usually a 2 to 3 Hp range.
This will explain it better than I can
http://www.stens.com/assets/media/pdf/2012_engine_model_number_guides.pdf
I am not conversant enough to tell you the exact differences from spec to spec however most can be found here
https://www.smallenginesuppliers.com/html/engine-specs/briggs-engine-specs.html
And you need t remember that your shredder uses an obsolete engine so you are looking at the differences between one obsolete engine and another obsolete engine.
Fabian
Could it be assumed that there should be a lot of 12hp engines floating about as they would be the more common engine size used on ride on lawn mowers?
