briggs intek pro 206 running problems
sgkent
does the carb have a mixture adjustment screw? Is the choke properly opening? Do you have new clean fuel in the tank?
Scrubcadet10
Moderator
Staff member
With a spark plug that looks like that, before I’d go after the valves I’d be checking to see if the choke is fully open.
That's a novel idea...
And check for a blown head gasket by running the engine for as long as you can then stop it and remove the dip stick
If you get wafts of smoke coming out then the gasket has failed
benali123
There is no mixture screw and the choke plate is operating correctly. Ne carb made no difference.
Which is why I am suspecting something more serious.
rcchristensenjr
I have tried new plug, but not re recently.
Its never really run that well. But has recently deteriorated to stalling and even back firing.
Like I say just fitted new carb, but no real improvement.
I've done the obvious like filters etc
rcchristensenjr
Find out if just one cylinder is causing problem by disconnecting one spark plug wire then reverse. May be sticky valve on bad cylinder if just one cylinder
Scrubcadet10
Moderator
Staff member
it's a single cylinder engine
Have you checked for a blown head gasket as Bert suggested?
