reynoldston
- May 23, 2011
- 92
- 5,705
I agree with Mad Mackie invest in a good service manual for this engine.
I wouldn't leave any liquid of any kind in an engine overnight and particularly any volume of it.
You need to get and read the parts manual and service manual for your engine so you know how compression release systems work and how they affect compression testing and leakdown testing results. Unless your engine has more than 500 hours of operation on it I doubt that it has much carbon buildup anywhere in it.
If this B&S Intek twin that has the air filter cover with 4 screws holding it down and is more than 3-4 years old then there may be a problem with the air filtering system. Some V twin models suffered from dust particulate injestion as the air filtering systems had air leaks down stream from the air filter. This dust injestion causes premature piston ring and cylinder wall ware which increases crankcase pressures beyond what the engine is designed to deal with and in time engine failure.
