Mr. Shamrock
- Nov 22, 2011
- 14
- 90
UPDATE: Cut the yard again today and the mower used exactly 6 ounces in the hour it was running.
It seems to have used less although I am cutting more frequently and I raised the deck one notch so there is little to no strain on the motor which might be a factor. So it looks like new rings will be needed to fix it right. Does anyone see an issue with using SAE40 oil through this season? I will tear back into next winter. It still doesn't put out any visible smoke and runs as good as new. I guess at $3.99 a quart and using 6 ounces per cut I could get 5 cuts per quart or in other words it will cost 80¢ in oil per cut. I guess I could live with that, but I won't!
