Briggs ELS500 stalls during mowing
AdamL84
Hey guys,
I just bought a Husqvarna LT18542 lawn tractor, with a Briggs and Stratton ELS500 18.5HP motor. The mower was purchased from my neighbor who said it starts and runs fine until he starts mowing. He mows for about 5-10 minutes before the motor stalls and won't start again for a while. I'm on a business trip, so I quickly replaced the battery (his daughter left the headlights on), the fuel filter, air filter/screen and changed the oil and spark plug. When I get back, I plan on taking the carburetor out and giving it a through cleaning, and fresh gas in the tank as well. Any suggestions would be welcome, so I can hit the ground running when I get home.
Cheers,
Adam
There is no vent on the fuel cap on AYP products.
Loosen the cap 1/4 turn & you are likely to find the problem solved.
AdamL84
Bert,
What are AYP products? New guy here.
-A
AYP is American Yard Products division of FHP Frigidaire Home Products, division of EHP Electrolux Home Products, which as of a few years ago was split off of Electrolux Home products under the corporations name of Husqvarna So that is Husqvarna, poulan, poulan pro, dixon, peerless transaxle, mcculloch, redmax, jonsered, I know I missed a couple.
Because of the price pressures that are forcing down mower prices the factories usually specialise in a single product type thus gaing the greatest volume efficency.
Each factory have patients as to things like clutch mechanisms.
So if it has a pto lever on the right running in a candy cane shaped slot or a PTO lever to the left of the steering wheel then most likely it came out of the AYP factory regardless of which colour it is painted.
AdamL84
wow, thank you both for the info!
