Fish
- Aug 2, 2013
- 11
- 5,130
Too much valve spring pressure? Something in valve train on that valve hanging up and not moving free?Here was a problem on some of the Inteks made @ 2004 or so, one of the lobes would wear down to almost round, and would cause all kind of squirrelly running problems.
Here, I put a black line @ where the lobe tip should be on this old junk cam.
View attachment 53732View attachment 53733
Because the lower lobe was designed to be running under the oil level it was assumed that it would require less hardening so that is what it got.Too much valve spring pressure? Something in valve train on that valve hanging up and not moving free?
I have a cam from a late 70's early 80's from a 3-3.75 hp Briggs that has the plastic cam lobes and gear molded as one piece with a metal shaft pressed through the center.How about the cams in the Briggs & Stratton 206 Intek engine.....Steel shaft with PLASTIC pressed on gear and lobes.... and they fit into the Briggs & Stratton Motorsports "Animal" single cyl racing engine....plastic lobes does make it real easy to gain lift & or duration though also makes it real easy to screw it up too!
I've got one on them somewhere around here!
Not a good engineering solution but it did save 5¢ on every cam.
