- Nov 29, 2014
- 24,995
B & S Coils should not be handed ( Honda coils are ) but if one of them was originally fitted upside down then it would not fire at the correc time ( if at all 0 due to the way that the Hall Effect Trigger works
So both coils should be fitted the same way round with the kill lead tab facing the cylinder .
FWIW
If flipped the induced voltage will be 180 deg out of phase
On B & S magnetron coils the voltage in the coil goes from 0 - peak negative - 0 - peak positive - 0
When the chip sees negative X µV it fires the coil
If the coil is on upside down it goes 0 - peak positive - 0 - peak negative - 0 so the spark will happen ( or try to happen ) just after the magnets have passed the laminations rather than as the magnets are passing the laminations.
So at best you will get a very weak ******** spark or at worst , no spark at all .
FWIW
