nicknsw
Hi @bertsmobile1, @sgkent, @StarTech, @SeniorCitizen,
I'd like to thank each of you all for your help, but with the last snippet of advice from Bertsmobile1 regarding the "internal governor" I think I have come to the end of my skillset to take the engine apart. To be honest, other than moving the valve in the carburetor I don't know what I'd be looking for. Everything has been through trial and error
I have double checked the governor arm, and the assembly nut, the entire rig (assembly arm + governor arm + throttle plate) moved freely when I move the arm manually. Further, I can also see the valve in the carburetor opening and closing, there is no friction there, it doesn't stick. So, I'm inclined to take Berts advice that the "internal governor" is not working, although I do not know what this does beyond opening and closing the valve in the carburetor.
Last ditch effort with my latest video to show the governor assembly the the internal "knocking" sound it makes, which is performed freely, no friction.
https://photos.app.goo.gl/LKP9WevR2WZ4GRTB7
If I was to take it to a mechanic to look and fix how much time do you think it would take to fix? Time is better than asking what it costs... that I can work out with the former. Again, thank you everyone.
