I think I read that you adjusted the governor. Not everyone knows how to do this correctly. The correct way, for those that might not know, is to have your throttle control (on the machine handle) to the SLOWEST position. then while looking at the governor shaft and arm on the engine block, have someone move the throttle control (on the machine handle) all the way to fast/choke position, and observe the rotation of the governor shaft and arm under the spring tension of the gov spring. While in that fast/choke position, loosen the governor arm (with the linkage on it) that is on that shaft and rotate the shaft AS FAR AS IT WILL GO @ THE "SAME" ROTATION as you saw the shaft and arm move when going from slow to fast. The throttle control must remain in the fast position while doing this to keep the integrity of the gov arm to throttle control arm in tact.
