I once had a English 1558 Lotus engine whose valve guides had a circlip to stop movement of the guide. I cannot remember if the clip was bottom side (stopping upward movement), or top side. Wonder why that technique is not apparently used? Also if guide movement is always upward why not circlip the bottom side? Maybe cause once the head grip is lost the guide will move in either direction it can and mfgrs figure less damage upward?? That direction " only "destroys the cam lobe as it slowly grinds down to a perfect circle. Also on the subject of pushrods in sump...When I opened the engine and could not find the pushrod it took a number of self arguments that the pushrod could possibly have gone into the sump thru the tiny oil passage hole, but it did. I remember that Briggs had purposely left in some casting spider webbing accross the hole, which I cleaned out to improve oil "mist " return. Crazy
