Boudreaux In Eunice La.
- Jul 22, 2017
- 2,154
Do you know if I can use the tractor as-is one more time? Maybe clean the spark plug a few times during the mow and keep checking the oil?
Jamie if you have a blown head gasket, then NO do not run it at all.... Gas will keep going into the oil and you will be spending 2 K on you mower.........
Drain the oil and see what is going on..... If your oil is real thin and smells like gas you got a blown head gasket.......
You already said that you have smoke coming from the dip stick..... Like a cigar in a ashtray....
Did you watch the video that I sent you ??? If you keep running that engine you will be cutting grass with a new mower......
Let us know Mon Ami ~!~!
