- Nov 29, 2014
- 24,995
Thanks Bert, "easy bit" might be overstating my understanding. Be that as it may, I have some questions that may indicate how deep my ignorance is;
I assume, and correct me if I am wrong, that a failing head gasket and/or a failing valve guide would, to some extent, affect the performance from the cylinder that had one or both of those conditions. If one were fortunate enough to have BOTH of those conditions occur in the SAME cylinder (rather than one condition in each cylinder), then would pulling the plug wire on one cylinder at a time (and running the engine) give one a reasonably good clue as to which cylinder was so affected? That is, pulling the plug wire on the cylinder that is NOT affected would allow the engine to run "better" than pulling the plug wire on the good side.
Would the so called "compression run off test" reliably confirm which side is fouling things up?
If the valve guide or head gasket has failed on the side that "powers" the fuel pump, would the fuel pump keep on working?
As others have suggested elsewhere, if I suck and blow on the breather tube that leads to the carb from the crankcase, will that reliably confirm or deny that the breather valve is operational? Common sense leads me to believe that for the breather valve to be a cause for pressure to build up in the crankcase, it would have to be stuck in the closed position, but if it was stuck closed, wouldn't that mean I would NOT see oil coming out of the breather tube into the carb?
Thanks for your time and have a "Goo'day Mate" (hope that isn't offensive)
J R Clark
You have to remember we are talking about a very basic engine engine here, not a 100Hp / liter top fuel drag engine.
In many cases the engine will run and cut grass quite fine with a broken con rod thus only running on one cylinder and a lot come into the workshop just like this with the owners stating " it seems to bog down in long / wet grass "
You will not notice much till the gasket has totally failed and the cylinder has no compression at all.
Usually the first indiction is smoke on start up, followed by smoke for 10 minutes after start up, progressing to hard to start & smokes all the time followed by won't start at all and this can span several years.
No one ever noices the drop off in power because most mowers are overpowered by a facor of 2 to 3. Except for bagging 4 Hp per 1" of cut is generally all the power required. Most modern mowers run near 2Hp / 1" ( GT mowers).
Pulling plug leads is a standard test and yes if it runs better ( or no worse ) then that is the problem side just remember to earth out the idle plug as some ignition modules can not cope with wunning full spped open circuit and they are expensive little buggers to replace.
The fuel pump is also way over capacity required but yes eventually it willnot be able to keep up however remember that the whole internal space is all connected together.
Kohler Courages can develope a crack from the top of the engine case to the bottom and most will contine to get enough pressure pulse to run till all of the oil has drained out the crack, then the don't run.
Most times the vent valve will not stick totally closed but remember it has to open & close 7200 / minute on a twin so just going slow will make a big difference.
Because of the shape of the chamber, oil will condense in the bottom and flow into the carb even if the valve is not working properly but yur original assumption stands, more likely to be failing gasket than the valve but you check the easy bits first.
Blown gaskets need to be presure tested to be definative.
You pressreize the cylinder with the piston in the firing position and then listen for escaping gasses and even then it still could be rings.
Gaskets are designed to fail early in these engines and are quite cheap and relatively easy to replace.
Do them one at a time with the piston in firing position so as not to put strain on anything when tightening down the head.
25 ft/lbs of torque is very low and even a desk jocky can exceed this using a 6" wrench so be careful when tightening the head bolts.
And no offense.
It is a soft G prounounced sort of Ger but very short & written as G'day
