Engine Briggs 18 hp Vanguard engine
Thanks Bert, "easy bit" might be overstating my understanding. Be that as it may, I have some questions that may indicate how deep my ignorance is;
I assume, and correct me if I am wrong, that a failing head gasket and/or a failing valve guide would, to some extent, affect the performance from the cylinder that had one or both of those conditions. If one were fortunate enough to have BOTH of those conditions occur in the SAME cylinder (rather than one condition in each cylinder), then would pulling the plug wire on one cylinder at a time (and running the engine) give one a reasonably good clue as to which cylinder was so affected? That is, pulling the plug wire on the cylinder that is NOT affected would allow the engine to run "better" than pulling the plug wire on the good side.
Would the so called "compression run off test" reliably confirm which side is fouling things up?
If the valve guide or head gasket has failed on the side that "powers" the fuel pump, would the fuel pump keep on working?
As others have suggested elsewhere, if I suck and blow on the breather tube that leads to the carb from the crankcase, will that reliably confirm or deny that the breather valve is operational? Common sense leads me to believe that for the breather valve to be a cause for pressure to build up in the crankcase, it would have to be stuck in the closed position, but if it was stuck closed, wouldn't that mean I would NOT see oil coming out of the breather tube into the carb?
Thanks for your time and have a "Goo'day Mate" (hope that isn't offensive)
J R Clark
You have to remember we are talking about a very basic engine engine here, not a 100Hp / liter top fuel drag engine.
In many cases the engine will run and cut grass quite fine with a broken con rod thus only running on one cylinder and a lot come into the workshop just like this with the owners stating " it seems to bog down in long / wet grass "
You will not notice much till the gasket has totally failed and the cylinder has no compression at all.
Usually the first indiction is smoke on start up, followed by smoke for 10 minutes after start up, progressing to hard to start & smokes all the time followed by won't start at all and this can span several years.
No one ever noices the drop off in power because most mowers are overpowered by a facor of 2 to 3. Except for bagging 4 Hp per 1" of cut is generally all the power required. Most modern mowers run near 2Hp / 1" ( GT mowers).
Pulling plug leads is a standard test and yes if it runs better ( or no worse ) then that is the problem side just remember to earth out the idle plug as some ignition modules can not cope with wunning full spped open circuit and they are expensive little buggers to replace.
The fuel pump is also way over capacity required but yes eventually it willnot be able to keep up however remember that the whole internal space is all connected together.
Kohler Courages can develope a crack from the top of the engine case to the bottom and most will contine to get enough pressure pulse to run till all of the oil has drained out the crack, then the don't run.
Most times the vent valve will not stick totally closed but remember it has to open & close 7200 / minute on a twin so just going slow will make a big difference.
Because of the shape of the chamber, oil will condense in the bottom and flow into the carb even if the valve is not working properly but yur original assumption stands, more likely to be failing gasket than the valve but you check the easy bits first.
Blown gaskets need to be presure tested to be definative.
You pressreize the cylinder with the piston in the firing position and then listen for escaping gasses and even then it still could be rings.
Gaskets are designed to fail early in these engines and are quite cheap and relatively easy to replace.
Do them one at a time with the piston in firing position so as not to put strain on anything when tightening down the head.
25 ft/lbs of torque is very low and even a desk jocky can exceed this using a 6" wrench so be careful when tightening the head bolts.
And no offense.
It is a soft G prounounced sort of Ger but very short & written as G'day
mysticheadlice
Well, considering that I am gainfully employed, and with Spring fast approaching, I find I have more money than time. Thusly, I have decided to go ahead and pull off that head and replace it along with the head gasket and I will replace the breather valve at the same time. It is likely I will need to pull off the sump cover as well to replace the gasket. I say "likely" because I discovered today that at least one of the bolts (I couldn't reach the others) holding the upper half of the sump cover was loose (less than hand tight). To change the sump cover it looks like I will have to remove the crankshaft pulley that is attached by belts to the PTO pulley. Do you know right off hand if I am going to need specialized tools (other than a standard kind of pulley puller) to get that off? I guess there will be some kind of oil seal in there as well. I am thinking I should remove the pulley first and then see if a little tightening of the sump cover will fix the oil leak before pulling off the sump cover to replace the gasket (unless removing the sump cover is simply a matter of removing the bolts that hold it down). Any thoughts. Realistically, should I replace both heads like they usually recommend, rather than just one? The one I am thinking about NOT changing had the higher compression reading-150 PSI). Thoughts?
With the sump cover bolts being loose, I will guarantee that there is a piece of the gasket missing. You will also need to replace the seal around the crankshaft. Unless the pulley is rusted to the crankshaft a pulley should be all that is needed to remove. May be able to remove by hand after removing the retaining bolt.
I don't really think you have a head gasket problem You have problem that is causing you to run on one cylinder. Fixing that may solve most of the problems.
Yes the engine will have to come out.
Buy a full rebuild gasket kit it is cheaper & easier than finding out you are short 1 gasket.
Not sure if the kit for this engine contains the inlet valve seal.
The flywheel is generally a lot harder to pull than the pulleys.
Undo the pulley bolt while the engine is in situ then if necessary lever the pully against the underside of the mower.
Generally a std wrecking bar will work fine as most times the pulley drop off as soon as it is undone.
Rattle guns make the job a lot earier.
Watch for a loose drive key some have them while ohers are part of the pulley and any spacers between the pulley and the crankcase.
If you have an electric PTO then you will need a deep socket to get in there.
Most are 9/16 or 5/8.
Ditto for the flywheel, a lot easier to remove with the engine firmly bolted to the mower.
Get a milk crate or similar and make a 1 &1/2 " hole in the middle to drop the engine on to when working on it or make a frame out of real 2 x 4's, again makes life easier.
Don't forget to drain the oil before you start then once out lay the engine on the oil plug side to remove the rest of the oil ( well most of it any way) .
I have some stands that fit inside 25L ( 5 gallon to some ) plastic drums cut in 1.2 lengthways.
This not only contains the rest of the oil but also traps all the fiddle bits that otherwise fall off and end up in that parrallel universe along with all of the left socks and spare keys.
Cover you work with some cloth ( I use old denim ) or in the morning it will be full of wasps, beetles and moths. They seem to love to crawl in the bottom of a deep hole & die there.
Allow a couple of weeks for the job as while the heads are off take them to a head shop and get the valves & seats done. Most will do a small job like that while you wait. If you have a real ower repair shop ( not part of a glass front retail outlet ) they will probably do the valves for you and if you go there for the gaskets the week before you can ask them.
I charge $ 10.00 a valve so a twin will cost $ 40.00 ( Aust )
Good luck but again as ILENGINE has already mentioned it is better to properly diagnose before you start wily nilly replacing perfectly good parts for no cause.
mysticheadlice
ILL Engine: Let me clarify, My first post about MY engine was #5 on this thread. It is probably my fault, but I couldn't see how to start a new thread on this forum and this one was titled "Vanguard 18 hp" so I just kind of jumped in. So the first 4 posts in this thread were about someone with a problem blowing out their oil dipstick seal, and some of that discussion may have leaked into the help you were trying to give me. My push rods and valve clearances are fine.
My problem is with the oil blowing into my carb through the breather tube in copious amounts, and by that I mean actually oil pouring out of the tube, not just an oily cloud of air. At the same time oil pours out between the seam at the top of the sump cover/block. So, something is causing a great deal of pressure build up in my crankcase. I appreciate your thoughts on all of this, but I simply don't see how these conditions could occur without something pressurizing the crankcase and I don't think running on one cylinder would do it. I think it has to be pressure coming from one of the cylinders, by way of a blown head gasket or a cracked head or a leaky exhaust valve guide, or I suppose a broken ring could do it but my compressions are 120/150. I don't think oil would leak out the top of the sump cover without significant pressure to drive it, i.e. the running engine is slinging oil all over the place inside the sump area and the pressure inside is pushing the oil out when it gets to that leaky gasket, without pressure, gravity would probably make the oil fall back down away from that leak.
This discussion, with you and the gentleman from Australia has clarified my thinking on it tremendously, i.e. I have learned a lot, and I hope I can continue to pick your brains as i proceed with this beast.
What are your thoughts on replacing just ONE head rather than two? It seems many think by introducing a new head, the previous wear and tear on the old one will create some kind of mismatch between the two sides.
Thanks, John Clark, Keene, KY
Well that explains a lot.
To start a new post you need to be o the index page of the particular forum.
That is the first page with the list of all the posts on it.
On the left side is a green button "Post new thread".
You click on it and start typing.
It is not good idea to tack onto another thread as it confuses every one and you will end up getting repair advice for the original posters problem.
Valve guides won't cause oil to get into the breather tube. You said it wouldn't start with one of the spark plugs disconnected but would on the other. Which confirms you are running on one cylinder. Even if you had a blown head gasket on the low compression cylinder, 125 psi is still plenty for it to run on. I am thinking you may not have spark on that cylinder for some reason.
The missing piece of the sump cover gasket most of the time doesn't come all the way out, It gets partially sucked in but hangs, so when the pistons go up it sucks air into the crankcase. When they go down that piece can act like a one way valve, and then the extra pressure gets pushed out of the breather. I would still remove the breather and make sure it is operating properly and that the drainback holes are not clogged. I have see cases where the read valve gets broken which can also cause oil in the breather.
Running on one cylinder can cause fuel dilution of the oil on the cylinder walls, and thin the oil. I would worry about the leaking side cover gasket and inspect the breather and if damaged then replace it. But I wouldn't worry about the head or the gasket until everything else is confirmed.
mysticheadlice
Sorry about the "interlude". As Ill knows, it suddenly got cold again and wasn't much I could do out there until it warmed back up. Well, that and having to turn my attention to wood splitting and hauling and keeping a woodstove going 24 hours a day- a bigger job than most people appreciate.
I have read these posts through again and the only update I have is that I do indeed have a good spark on both cylinders. I have spoken with a couple of shade tree small engine mechanics and all 3 of them were of a mind that the most likely cause for my problems was a blown head gasket. They agreed that there were other potential causes and that of course there could be more than one problem going on. I should mention that the head with the lower compression that won't start on its own, is a head I replaced about 4 years ago when it lost all compression and when I pulled the head I found that one of the valve seats had popped up out of its proper location and was wedged under the valve, preventing it from closing. I was told the valve seats could not reliably be replaced and that I would have to replace the head, so that is what I did- ran great after that. Since this is the same side that I think is giving me problems now, I wonder if for some reason that side of the engine is getting hotter than the other. Just food for thought. I couldn't find anyone with enough experience with this particular engine to say whether or not having problems with this particular side (drivers side= ?#2) was common with this engine.
Be that as it may, I am planning on tearing into this thing shortly. My goal is to inspect and replace the breather valve, pull off the head and inspect and replace the gasket and have a local machine shop examine and rebuild that head (of course I will inspect the cylinder wall etc while I have the head off). I'll remove what all I need to in order to replace the sump gasket and take a look inside there for stray bits of metal and signs of wear and tear etc. I don't currently see myself tearing down the lower part of the engine but depending on what I find, that could end up on the agenda.
All for now, the grass is back growing today :eek:(
