JonnyBlaze
- May 6, 2017
- 338
Not sure what to do next.WELLLLLL put the dang thing together and let's GITTTER-DUN !! ..:thumbsup:
I swear I saw it move just a little bit. If it's not the decompression mech, then what am I doing wrong? I've done this before on another mower. Same motor.Good they are opening and closing, but is the inlet opening a second time , just a tiny bit just before TDC to decompress th cylinder.
If not the decompression mechanism is not working.
If the engine does not decompress then the starter motor can not spin the engine fast enough to start it.
Right. Thanks. So I'll order a gasket set and dig into it and see what I find inside.
John I have NOT checked the parts list for YOUR MODEL of engine, but the compression release may be part of the camshaft, just a heads up in case you need to order that as well...... I believe you have the Parts Manual for that engine .. ??
