JonnyBlaze
Model: 31F707 Type: 0112E1 Code: 0301167E
Ok, Ive adjusted the valves 10 times and same result. Turns over fine without the spark plug in it with the key, but put the plug back in and it only makes one revolution. I'm not sure what to do. I used the same youtube video I used when I did the headgasket on the last Briggs I worked on.
Any suggestions? I read somewhere about a decompression valve or something. I'm not afraid to open this motor up as I have done it before on another Briggs. Just don't want to waste my time til I know for sure.
