Fixed up a craftsman tractor over the winter with a 17.5 briggs engine (31c707 0230 e1) I've always had trouble getting this thing to run smoothly. It was running pretty well yesterday then I put the shroud and air filter on today and it wants to surge again The rpm will fluctuate a little bit and I'll get some random popping sounds. Can anyone tell me if the governor arm should be all the way to its stopping point while running with the throttle lever at max? The governor arm will reach its furthest point using the throttle lever while the engine is off, but while running it does not make it this far. Pushing the arm with my finger will rev it up, none of the linkages are binding. I've done the following already:
New head & gasket, valves lapped, new plug, seafoam/oil change
new carburetor(s), set throttle cable on its bracket, new air filters, fresh gas
even tightened up governor spring a tiny bit
Starting to wonder if i can get my hands on a carb with high speed adjustments for this motor or something similar. Also, bending the tang for the governor spring doesn't increase top speed right? The arm has a hard stop so I assumed putting more tension on it just gets me to top speed sooner
