GravelyBrad
- Jun 19, 2016
- 10
Thank you for the links.
Well, first you probably need this: http://rich.homeunix.com/gravely/engines/briggs/16hp-single/01_270962SingleCylinderLHead.pdf (service manual)
If you pull the head, look for any burning/scorching around the valves, valve seats, head/cylinder mating surfaces/gasket, that the valves move properly, excessive valve/valve seat wear, etc..
Here's another manual that might interest you: http://rich.homeunix.com/gravely/engines/briggs/16hp-single/13_CE8069RepairmansHandbook19191981.pdf
