best way of leaf removal
slammed
You could but the problem with buying one is someone would have to make it just for the kind of mower you have. But you could ask your friends if they have a welder you could use or if they would help you make one.
slammed
They would with some modifications to how they mount.
I used my Echo PB-255LN to get the leaves off our lawn and into the street....it worked even better than I expected!! I will use that now also along with sucking them up with my mower(s) and using a rake. (Attached is a picture of when I was halfway done.) :smile:
And here is a pic of the pile in front the house:
midnite rider
It may take longer but a good old fashioned rake will always work and requires no fuel. :biggrin:
