Best Grease for Honda Rear Wheel Drive Components?
I and my commercial customers use dry lithium spray grease
Domestic customers once a season, commercials once a month
civic
This straight out of the Honda Manual
dawgn86
i never knew those pinion gears had a punch mark that needed to be facing a certain way.
I would use silicone spray. Grease = disaster on a mower. Silly cone spray is very light and will dry or drip off. Silicone is also anti moisture slash water.
Honda uses an inferior drive system.
civic
I use what is recommended by the manufacturer and I double seal so no dirt gets in. Double sealing is the trick. I have on occasion tilt the mower on its side remove the seal use a grease needle inject grease.
