Shughes717
- Jun 12, 2014
- 4
- 1,230
You need to read my posting because I basically agreed with you to a point, I said... Not saying your theory about Larger tires, weight, and suspension making a difference in the ride doesn't have merit but it isn't necessarily hold true either, it just depends on what mower your talking about that was the reason I used the GS as an example because according to what you say it should be a terrible riding mower due to the smaller tires and lack of weight and the thing that makes meis the fact it's a better built mower than either of the mowers were talking about including drives. As far as substantiating my claim about the thicker frame improving the ride? I don't have to substantiate that because you already did. Your own words ( Lol, it's not a theory saying larger tires, weight, and suspension improves the ride.) It stands to reason that a 3" x 1.5 10 ga. frame will weigh more than a 2" x 1.5 11ga. frame. As far as my rops and where it's mounted, it's mounted to the frame behind the seat.
Gotta go Dallas and the Seahawks are playing
You say the z master weighs less, so how did I help substantiate your claim? You have not explained how the 3 x 1.5 10 ga. Frame helps the ride one bit. As for the gs it is a different style mower all together. What do you think your legs are working like when you are mowing when on the gs. A suspension! Thanks for helping prove my point. Not comparing apples to apples. I don't think the gs is better built than either the z master or the s150xt. Just a different style mower. The rops may not fold in the same place on the z master as it does on the s150xt either. As I said earlier the only way to know which sits lower is to measure from the ground to the seat not from the ground to the top of the folded rops.
