Belt Dressing
RayMcD
Gentlemen, do you routinely use belt dressing on you mower belts? If so what brand, thanks Ray
Hammermechanicman
Nope. Don't use belt dressing on belts used in clutching applications.
If you need belt dressing to stop a slipping belt you need a new belt or pulleys.
Belt dressing is designed to be used or raw edge automotive belts.
$.02
Scrubcadet10
Moderator
Staff member
$.02
x2
so.. there's my $.04
Belt dressing only goes on naked belts
Most mower belts are wrapped
Some hydro belts are naked but no never used a belt dressing on a mower.
gearz
I agree never use belt dressing especially on Kevlar belts. You may have miss aligned or worn pulleys so it best to find the cause. I didn’t even know you could buy that stuff anymore.
If understand belt dressing, they are sticky in nature. You definitely don't to use it in the mowing environment as you are constantly having fine abrasive materials getting the belt paths which cause more problems than it resolves.
