I just checked ac coming from the stator and one post did not read anything and the other moved a little past -20. I hooked the rectifier back up stuck the probe in the red connector after switching the meter to the 250 DC setting and the needle never moved at all. I had the black probe grounded to - on the battery, I also tried with probe connected to the chassis ground. Both tests resulted in the same.
Bad stator correct?
Thanks
Wade
Check the AC wires from one to the other... Check the DC to battery negative but use the 20 volt scale... :smile:KennyV
