djdicetn
- Sep 3, 2012
- 12
- 2,193
How thick is that Kevlar strip? And how wide(not the length across the deck but the height of the strip when attached)? Like user Carscw pointed out, it should only extend 2"-3" below the bottom edge of the deck. I don't know of any way to attach it other than removing the deck, drilling some holes across the back of the deck, drilling matching holes across the strip then fasten it with bolts & nuts(inserted from inside the deck as not to interfere with the blades). It would probably also be a good idea to fasten it with a 1/2" to 1" flat metal strip all the way across the outside of the deck to keep it from tearing loose at the bolts. NOT going to be a real easy job and will require you to remove the deck. But......it could be done. If it were me I would check on an OEM striper kit before trying a homemade one. You may find that it isn't very expensive and it will be a much easier installation.Can I use a rubber strip. On the rear of the deck to stripe? I really don't want to spend the dollars for a kit I just want stripes! I have a Kevlar strip from a keelguard ; came off my boat should be durable. Any help would be great!
