I have a bad boy revolt with a Kawasaki FX850V. I changed the battery after it died a couple of weeks ago. The new battery died soon after changing. I found the voltage regulator was bad. I changed the regulator and jumped off the battery to get the mower started. Voltage between the regulator and the battery is now showing 8V while running. There was no voltage before.  Is the new regulator bad?  What else could be the problem?  I was hoping that running the mower with the new voltage regulator would charge the battery back to 12V but it’s not going to get there with only 8V being supplied. Any ideas?
