I have a log splitter engine I need to check out. It's the original that came on my log splitter.
It's a B&S Quantum XE 5.5HP engine. I used it once in the cold (0-10 degrees F) and it died after a minute of running. It was always stored in an unheated garage. I couldn't pull the cord when I tried to restart it with the hydraulic lever in the neutral position. I assumed the oil (SAE 30) was too thick and I fried the piston. So I replaced it with a used one I found. Now the replacement is falling apart.
Since then, I can pulled the cord easily. So I would like to take a look at the piston or at least the cylinder wall before I try to restart it. Not being an engine guy, I'm not sure what I need to do first. I'm guessing remove the spark plug cylinder head? and I should get a view of the wall? What do I need to remove to get a look? Any advice is welcomed.
What could have caused this failure? It was new and used very little at this point. Was it all in my head?
