B&S Engine on Weedeater 500 push mower starts but dies after priming gas used
greynold99
I have 5 year old Weedeater 500 with a Briggs & Stratton engine. When I went to use this mower last week I encountered a problem
After priming, engine starts right up but dies as soon as priming gas used up.
At the end of last season's mowing, I ran the mower till the engine died and then tilted the mower to empty out the remaining gas .
This year after fresh oil change and gas filled, I encountered this issue immediately on attempting to start.
After trying a new sparkplug, checking the air filter, I came to the conclusion that the carb might need rebuilt. I just happened to have a new carb that I installed but surprisingly encountered the exact same problem afterwards... Engine starts immediately but dies after priming gas used up.
On searching this forum I came across a similar report from several years ago of the same issue with a Weedeater brand lawnmower, which that person indicates they were able to fix. I wanted to ask if anyone can confirm/explain if what this person indicates solved his problem: by removing the safety-lever/brake mechanism, the wire-bale on the handle that you have to hold down when starting/running the mower. Aside from the safety implications,
I was not aware that the wire-safety handle had any function other than to act as flywheel-brake to stop the running engine. Is there some other mechanism at work with the flywheel brake? I remember from the old lawnmowers where there was a Slow-to-Fast throttle control mounted on one side of the handle and that the control lever had an OFF or STOP setting that stopped the engine when you pushed it all the way to the OFF setting.
Does the flywheel-brake mechanism have any such function that might explain Why the engine won't run - though that totally ignores why the engine will start with priming gas...?
Something else I came across was that the priming gas mechanism operates differently than the normal running-gas mechanism when the engine is running normally. And it struck me that I really don't understand how these B&S carburetors work. I'm assuming it's using engine compression to create vacuum pressure in the carb when you pull the cord, to pull gas up through the long narrow tube that 'sits' inside the gas tank and then to transfer the gas to the larger diameter but shorter cylindrical tube that's covered by a wire-mesh screen. From here it looks like the gas is routed to the intake-tube for the combustion cylinder. That's the limit to how I think the carbs are working but appreciate anyone's better explanation if not complete or accurate.
Thanks,
greynold99
You're right, the lever you hold for starting has two functions, low tension wire to kill the ignition and a brake pad to slow the flywheel under 2 seconds.
It's not common for these to have an issue.
We don't have this machine in the UK so I'm guessing the engine type. From your description it would seem like the diaphragm is faulty. If you can supply all the engine codes we should be able to give you part number. These numbers are often stamped into the blower housing. I can't post a link here but, if you go to wwwbriggsand stratton.com and go to their support page you will see where to look on your engine for the engine numbers/code.
Good luck, Phil
edit, here it is Push Mower Engines
This is a classic no fuel situation.
I assume you have a sprint engine on the weed eater with the fuel tank under the carb.
If this is the case then as above, diaphram & gasket is a good place to start.
If it has a quantum with a petrol tank above the carb, check the fuel lines and make sure the float bowl is getting fuel.
