Kennykenny
I'll stay tuned. Whatever you do, don't assume that my list is too hard because it covers the whole page. :laughing:
Primer,
I am working my way through your list. The diagnosis is going well. All looks goog thus far. Is it possible to give more detailed how to insturctions on how to do the checks on steps 8-10? I am not sure of some of the items that you are describing and how to proceed through these steps. Thank you.
8. Inspect the intake tube (plastic tube from carb to engine) and ensure that it is free of cracks. Make sure the bolts holding it to the engine are not loose. You will have to remove the metal shroud to do this.
9. While you have the metal shroud removed, make sure there is no debris preventing the governor and throttle linkage from operating properly.
10. Inspect the head gasket to make sure it's not blown. Ensure that all cylinder head bolts are tight.
