The model is 20332. Are you meaning the serial number? It is, 290088286. I did get the Troy-bilt fixed thanks to you....
The mower and the engine have separate model numbers. This page from Briggs and Stratton shows you where to find the one on the engine:
https://www.briggsandstratton.com/na/en_us/support/need-help/push-mower-engines.html
Glad you got the Troybilt fixed! :thumbsup:
Did you run a small piece of wire or anything through all the small passages/jets inside the carb while cleaning it? Just this past winter I was fixing a snowblower with the same issue and I could see through the jet when I held it up to the light but still had an issue once back together. Took it back apart ran a wire through everything and sure enough gunk was on the end of the wire after running it through one of the jets and it was just enough gunk left in there to cause an issue cause it ran just fine afterwards.
When you say "runs rough." Does it sputter and pop, does it surge or does it do all of the above? Also, does it produce any smoke while running?
This is an autochoke engine, right? No primer bulb? If so, I think that's the problem. Either the autochoke linkage is hooked up wrong, or the actuator spring on the muffler has failed.
Start the engine and try moving the autochoke lever manually to see if it makes a difference. The autochoke lever is the large, black plastic lever that opens and closes the choke valve on the carburetor. The choke should open when the engine starts and stay open as it runs. You can remove the air filter to verify that the choke is opening all the way. If it isn't opening all the way, that could be your problem.
I noticed in your second picture the linkage return spring is disconnected. (Stretched silver spring. This is not the actuator spring.) Did you disconnect it for pictures, or was it disconnected to begin with?
If you start the mower and attach a zip tie to keep the choke open, will it run properly or does it still sputter?
(Just make sure you don't zip tie the throttle open - your engine could explode! The choke valve is the one nearest to the air filter. Throttle is closest to the engine.You probably already know this, but I'll mention it anyway in case some less knowledgeable person sees this thread.)
There are two flaps (butterfly valve is the technical name) in the carb. One is the throttle, other one is the choke. I circled them in the picture to show you which one is which.
The choke should be closed when the engine starts and all the way open when the engine is running. The engine won't start cold with the choke open, so what I would do is:
1. Zip tie the choke fully open.
2. Put a quick shot of starting fluid in the carb throat to prime the engine.
3. Start engine and see if it runs better.
Hitherto, I have been giving you one thing at a time to check. However, this is too slow of a process for both of us. Therefore, I will give you a list of all the things I would check. It may look intimidating, but it will probably take you less time to do everything than it has taken me to type this list. :wink:
1. Make sure the mower blade is installed properly and in good condition. Make sure the blade adpator cannot spin on the crankshaft. The mower blade acts as a secondary flywheel, and the mower will exhibit the symptoms you describe if the blade is missing or excessively worn. Be sure to tip the mower so that the carb is facing up to prevent oil from draining out the crankcase breather.
2. Did you drain and clean the gas tank before reinstalling the carburetor? If not, drain it and clean it with fresh gas. Make sure the fuel line is free of obstructions. Then drain the gas from the carburetor and re-assemble everything. Bad gas or an obstructed fuel line can cause the symptoms you describe.
3. Make sure the three inlets in the carburetor bowl bolt are all clear of obstructions. The passages within the bolt form a "T" . If one or more of them are clogged or obstructed the engine will exhibit the symptoms you describe.
4. Ensure that the spark plug is gapped correctly. I would set it at 0.025 inches.
5. Attach an inline spark tester to make sure the magneto is working properly. If you don't have an inline spark tester, skip this one for now, as it's one of the less likely causes.
6. Remove the muffler and see if the engine runs smoothly without it. If so, you have a clogged muffler.
7. Ensure that the O ring behind the carb is in good condition.
:thumbsup:
8. Inspect the intake tube (plastic tube from carb to engine) and ensure that it is free of cracks. Make sure the bolts holding it to the engine are not loose. You will have to remove the metal shroud to do this.
9. While you have the metal shroud removed, make sure there is no debris preventing the governor and throttle linkage from operating properly.
10. Inspect the head gasket to make sure it's not blown. Ensure that all cylinder head bolts are tight.
If none of these are the problem, I'll suspect one of three things: sheared flywheel key, bad carburetor or valves not seating properly.
If you could take a video of the engine running for me to listen to, that would also help. History of the problem would also help. (Did it begin while you were using the mower, or did it begin after the mower was in storage for a while?)
If you need any help with the items on my list, let me know. I assure you, these inspections/repairs are easier than they sound.:thumbsup:
I'll stay tuned. Whatever you do, don't assume that my list is too hard because it covers the whole page. :laughing:
Primer,
I am working my way through your list. The diagnosis is going well. All looks goog thus far. Is it possible to give more detailed how to insturctions on how to do the checks on steps 8-10? I am not sure of some of the items that you are describing and how to proceed through these steps. Thank you.
I've got to run now, but I'll give you more details after dinner. :thumbsup:
Okay, so judging by your pictures you already have the decorative plastic shroud off. Now you need to remove the metal shroud that covers the flywheel and cylinder. In order to do this, first you need to take off the gas tank. There are 4 bolts holding it on, 3 around the starter and one under the gas tank at the back of the engine. (It's on the carb side of the engine.) With the bolts removed, clamp the fuel line with a vice grips and disconnect it from the carburetor. Then you should be able to lift the gas tank off the shroud.
After removing the gas tank, you can remove the metal shroud. There are 5 bolts holding it on. Two are at the front of the engine, above the spark plug. Two are at the very back, holding the shroud onto the engine block. The other one holds the oil disptick on. Remove it and then rotate the dipstick assembly to get it out of the way. (It's just held onto the engine block by an O ring, so it should rotate easily. ) After this, you can pull the metal shroud off.
With the shroud removed, you will be able to access all the parts in steps 8 and 9. The plastic intake tube goes from the carburetor to the engine. Make sure it is in good shape and the bolts holding it to the engine are not loose.
You will also be able to see the governor linkage (number 9.) It consists of the parts connected to the throttle. Make sure it's free of debris and moving freely.
Step 10 is the head gasket. It's the gasket between the cylinder head and the engine. The cylinder head is the part that the spark plug screws into. The head bolts are the bolts around the spark plug. Make sure the head gasket doesn't have any obvious leaks or holes in it. Don't take the cylinder head off, just do the best you can with it attached.
If it tries to starts and stalls with the carb cleaner but won't start at all without it, it must be a carb issue. I would replace the carb and see if that fixes it. You really don't want to get into the cylinder to check the valves unless it's absolutely necessary, as you're supposed to have a torque wrench to tighten the head bolts during reassembly. Checking the flywheel key is a difficult job as well.
Don't buy a carb just yet, let me look one up for you. You have to be careful as there are lots of junk Chinese carbs out there.
If you decide to go with a new carburetor, here's the one I would get: https://www.amazon.com/Briggs-Stratton-799866-Carburetor-Replaces/dp/B00CNWWNGW
Might be worth a shot to try troubleshooting the old one before spending $32 on a new one, since I'm not 100% sure that the carb is your issue. As far as what's wrong with the current one, I'd suspect either the float or the needle seat. This is assuming that
- The gas tank contains fresh, new gas.
- The fuel line is not obstructed.
- The carburetor has been thoroughly cleaned otherwise.
When I clean/rebuild a carburetor of this type, I typically replace the following parts:
- Float
- Needle valve
- Both bowl gaskets
- Needle seat
These parts can be obtained by purchasing the following two kits:
http://www.ebay.com/itm/WALBRO-OEM-...ash=item41c3856d73:m:mitMQjpy0Jjt171UugWDZVA\
http://www.ebay.com/itm/GENUINE-Wal...960839?hash=item3f44211e87:g:A08AAOSwdIFX0dFG
Thanks for posting the history of the problem! Did it appear over time, did it appear all at once while mowing, or did it begin between mowings (mower ran fine one week and wouldn't start the next.)?
With your situation, after considering it some more I would recommend the new carb. With the new carb there's no chance something else in the carb is clogged or broken. :thumbsup: And you also have to consider the labor involved to fix the old carb.
If you were closer, I would tell you to go and pull the carb off the running Toro Recycler behind my shop and put it on yours to see if that fixes it. Unfortunately you live too far away. :frown:
- Float
- Needle valve
- Both bowl gaskets
- Needle seat
DOES IT HAVE THE BOWL WITH THE FLOAT OR DOES IT HA A DIAPHRAMI have a Toro push mower 20332 that has a B & S engine 6.75 HP. I am having a problem getting the engine to start and then when it does start it runs rough. I have disassembled the carburetor and cleaned it thoughly and reassembled it. The spark plug is good and has been changed.
Any suggestions on anything else to try or what the problem could be?
IF IT HAS THE BOWL WITH THE FLOAT CHECK THE NEEDLE AND SEAT BUT I THINK IT'S THE BREATHER IN THE BOLT THAT HOLDS THE BOWL IT HAS BREATHER HOLES I CLEAN MINE WITH A PAPER CLIP OR AN OLD BREAD TIE
The link that you provided for the carb led me to a used carb. I am assuming that it is not the one that you were suggesting? I saw the following one on Amazon for $32, https://www.amazon.com/Briggs-Strat...tton+799866+Carburetor+Replaces+796707+794304
Is this the new one that you were suggesting?
It has the float etc. I have cleaned the holes of the bolt a couple of times with no change.
HOW OLD IS THE GAS CAP SOMETIMES THEY CANT BREATH AN CAUSES A VAPOR LOCK
original cap. think that might be the problem?
If it was the gas cap, the engine would start, run fine for a while and then stall. It would not exhibit a no start condition, and it would run great when the gas cap was loosened.
:thumbsup:
Yes!!! :thumbsup::biggrin:Glad it's working now! That was a hard one to diagnose. Briggs carburetors are typically easy to clean, maybe yours had something else wrong with it. If it was a Tecumseh engine, replacing the carburetor would have been my first suggestion. Tecumseh carbs are nearly impossible to rebuild correctly.
Don't know where the part came from though. I'll take a look at my Toro tomorrow and see if I can figure out where it came from. (If I remember, that is. Don't hesitate to keep reminding me. :laughing![]()
I looked on my mower, and I'm not seeing it. :confused3:
As long as the mower runs, I wouldn't worry about it. :thumbsup:
It Works!!!!
I see your problem got resolved, congratulations! I just wanted to post in here an extra thank you to the diagnosers for the suggestions, as well as a thank you to the legwork by Kennykenny for trying all of the suggestions. Your efforts helped me resolve my similar issue the same way (replaced carburetor).
Thanks everyone!
Thanks everyone!
Make sure all the governor linkage and springs are still connected.
According to your picture, the throttle valve is not hooked up to anything. Thus, it is randomly vibrating around and causing the engine to run at random speeds. I'm on my tablet so I can't circle the problem, but here's a page that shows how everything is supposed to be attached. Note that the engine pictured does not have autochoke.
Compare it to your picture and I think you'll see the problem. http://outdoorpowerinfo.com/repairs/briggs_lms_carb_linkages.asp Don't follow any of the instructions on the page, just hook up the linkage the way it's shown.
I'm surprised the mower ran long enough for you to use it the first two times!
I'm guilty of missing it a few times as well. :ashamed:
Here's what's going on:
1. The cable that connects to the engine is basically a kill switch. The other end is connected to the operator presence bar (the bar you release to stop the mower.) In your case, the cable has come loose from it's mount on the handle, so when you hold the bar down it doesn't put tension on the cable. See the white zip tie on the handle? It's hanging next to a plastic bracket. The plastic bracket has a large hole in the top, parallel to the cable. I'm not sure how the cable got out of that hole, but it needs to be going through that hole in order for the mechanism to work properly. Disconnect it at the engine (easier than doing it at the handle) and thread it through the hole. Then hook it back up to the engine. If cpurvis sees this, hopefully he can circle the parts I'm talking about. I'm on my tablet again and can't edit pictures.
2. The broken spring (yes, it is broken) has nothing to do with the engine not starting. It's part of the self propel mechanism. Unless the self propel systems starts acting weird (the mower doesn't want to stop moving) I would leave it alone. I think I disconnected that spring on my old Toro to make it easier to operate, and I don't remember having any issues as a result.
Cable (circled in blue) must go through the 'holder' (circled in red). That cable should attach firmly to the holder. That might be what the zip tie is for, although I've put zip ties on handlebars to hold the operator presence bar in place so as to not have to keep restarting the engine. But this one is in the wrong place to do that.
Hope this helps.View attachment 32400
20332Model number of the mower? You may have posted it already but I am too lazy to find it.
Thanks!Just one correction though: the cable doesn't attach firmly to the holder, it's supposed to be able to slide in the holder.
The cable housing doesn't slide in the holder, does it? I don't see how a cable can work if the housing is free to move.
I guess I am still a bit confused about how there is tension on the cable when, as you stated in this post, " I don't see how a cable can work if the housing is free to move."
I think primerbulb120 may be right.
This "cable" arrangement works differently than a normal cable. In a normal cable, the cable itself is what moves whatever it is that needs to be moved. In this application, the cable housing is what does the work. Since the end of the cable is fastened to an immovable fitting on the engine, when one operates the operator presence bar, the cable itself is trying to pull on something that can't move. Because the cable end cannot move, the cable housing must move toward the cable end. When it does, it pushes the moveable kill switch/blade brake lever on the engine.
So I think primerbulb120 is exactly right--the cable housing must be free to move. Not loose in space as it is now, but held in its holder in a manner which lets it slide forward.
When you think about it, this is a pretty ingenious use of a cable. I would have never thought of it but it saves a lot of cable length and also having to make a 180 degree bend in the cable if it were to be used in a normal fashion.
:dance1::thumbsup:
The cable housing has to slide freely in that plastic holder on the handle. Reason being, the Personal Pace mechanism slides up and down on the handle, and the cable is attached to the Personal Pace mechanism. If the cable was secured firmly to the handle, you wouldn't be able to activate the self propel.
I have read all 8 pages of this saga. Wow what a pisser for you to go thru all that and now it doesn't run ~!~!
Do you have spark ?? If you don't then your cable is more than likely bad. The cable you have to use to start and kill the mower when you take your hand off of the handle. It is not traveling all the way.
That is one likely thing............ If you have spark then take the air filter off and squirt GAS in the carb with a old DAWN bottle. It will give you a good straight squirt in the carb. NEVER EVER use starting fluid.
If your choke is closed open it by hand and squirt the gas in it. Try to start it. If it don't start then you have a compression issue. Maybe ................
Did you take the head off the engine ?? If you did you should have put a new gasket on it and torqued it to specs.
Let us know Mon Ami ~!~!
I checked for spark...had a spark. I squirted gas in the carb. The mower started for a second or two and then died and wouldn't start again. No, I did not remove the head off of the engine.
Time for another carb clean Are you taking the old seat out when you put a kit in it ??
Sorry, didn't see this thread until now. By "wouldn't start again", you mean that it won't fire at all even if you give it starting fluid?
I took the carburetor apart and it seemed to be spotless since it was fairly new. I also cleared out the fuel line while I had it taken off the carburetor. It was clean too but cleaned it anyway. Put it all back together and the mower now starts. Not sure exactly what the problem seemed to be but I guess it was one of the things that I checked and cleaned. Thanks for the advice. I hope I don't have to check back with you guys again anytime soon on this mower.Something is up with the carb take the bowl nut off and clean the holes in it and wipe the bowl out good.
Let us know ~!~!
