Hitherto, I have been giving you one thing at a time to check. However, this is too slow of a process for both of us. Therefore, I will give you a list of all the things I would check. It may look intimidating, but it will probably take you less time to do everything than it has taken me to type this list. :wink:
1. Make sure the mower blade is installed properly and in good condition. Make sure the blade adpator cannot spin on the crankshaft. The mower blade acts as a secondary flywheel, and the mower will exhibit the symptoms you describe if the blade is missing or excessively worn. Be sure to tip the mower so that the carb is facing up to prevent oil from draining out the crankcase breather.
2. Did you drain and clean the gas tank before reinstalling the carburetor? If not, drain it and clean it with fresh gas. Make sure the fuel line is free of obstructions. Then drain the gas from the carburetor and re-assemble everything. Bad gas or an obstructed fuel line can cause the symptoms you describe.
3. Make sure the three inlets in the carburetor bowl bolt are all clear of obstructions. The passages within the bolt form a "T" . If one or more of them are clogged or obstructed the engine will exhibit the symptoms you describe.
4. Ensure that the spark plug is gapped correctly. I would set it at 0.025 inches.
5. Attach an inline spark tester to make sure the magneto is working properly. If you don't have an inline spark tester, skip this one for now, as it's one of the less likely causes.
6. Remove the muffler and see if the engine runs smoothly without it. If so, you have a clogged muffler.
7. Ensure that the O ring behind the carb is in good condition.
:thumbsup:
8. Inspect the intake tube (plastic tube from carb to engine) and ensure that it is free of cracks. Make sure the bolts holding it to the engine are not loose. You will have to remove the metal shroud to do this.
9. While you have the metal shroud removed, make sure there is no debris preventing the governor and throttle linkage from operating properly.
10. Inspect the head gasket to make sure it's not blown. Ensure that all cylinder head bolts are tight.
If none of these are the problem, I'll suspect one of three things: sheared flywheel key, bad carburetor or valves not seating properly.
If you could take a video of the engine running for me to listen to, that would also help. History of the problem would also help. (Did it begin while you were using the mower, or did it begin after the mower was in storage for a while?)
If you need any help with the items on my list, let me know. I assure you, these inspections/repairs are easier than they sound.:thumbsup:
