Wow this post really took off, first sorry for not posting but I got the carb on friday night and was busy all day Saturday so I couldn't put it on, I will be doing that today I hope, RevB thank you very much for that advice, and well you geussed correctly i do have access to compressed air, I was going to do that but I thought I might as well just get a new carb it's been a very long time since I got one, Highlife thank you also for the support I appreciate that, Justin I was very skeptical on rings but I did the putting oil down the spark hole to see if it seal the rings better, yes it also could get to the valves and seal those but it turned out I was right about the rings, I think it was also valves, cleverlever I think you might be right loll, disallow thanks for that support too, zippin you are probably right I haven't changed out that fuel in about 3 months I will definitely put fresh fuel in, Rivets I'm not sure what your point is in basically saying I'm a stuck up annoying teenager, I do know how to read a dial bore gauge, i dont think i know how to, i do, but im not a 30 year experience mechanic so its a new tool i havent used before so i had to double check my measurements on it, I borrowed one from my school and my teacher showed me how to, I already knew the basic of how to read it but he just brushed me up on how to, yes I also remeasured after honing why wouldn't I? I did also follow the manual on YouTube because that was the only place I could find it, and it's starting to look like I didn't compromise any of the engine while reassmbly it was just the carb, I rebuilt this engine probably over 3 months ago so no I don't remember the exact measurements, I didn't write the measurements down because they were farrr under the limit, and also why would I work on your equipment? I'm not gonna work on some random persons equipment from them "helping me" with a mower I needed some advice for, you helped me a little bit making me recheck some stuff though so I appreciate that though, again everyone I realy appreciate the help I don't think I could've found this on my own yes its kinda dumb that it is probably just the carb but the carb was never an issue before and I never did anything with it so it just completely slipped my mind that it would've been bad, I will be putting that carb on today hopefully and I will let you guys know if it runs good I'm praying it does lol, again I don't know everything and i think i dont know as much as i should because if i did know as much as i should than i would not be here asking for advice, i messed up a diag that wouldve taken any of you like idk
Delta Executor PC 10 mins to find out so yes i definitely don't know everything, I've made that pretty clear I think, but I hope this afternoon it'll run good and I will have learned to always check the carb on small engines lol
