djdicetn
- Sep 3, 2012
- 12
- 2,193
Hi everybody,
I have a brand new 2013 Zoom 42 with the mulching kit installed by the dealer. From the beginning, i new that there was something wrong. Every time I use it, there's grass clipping is flying in the air and falling on the deck, the leg rest and all over my legs. The grass is coming mainly from the front right side of the deck just behind the front right tire. First I ask my dealer if it was normal and they says to slow down while mowing and to not cut to much grass at the same time. All of this make sense and I tried it without much success. I then contact ariens client support and we manage to find that the dealer forgot to remove the rear baffle (the one that have a "3" shape) when installing the kit. I removed it and now it's better but still far from perfect. I'm wondering if the dealer can have reinstalled something on the wrong side (blade, strap, other).
The other thing is that it also leave grass clipping chunck everywhere on my grass and the clipping is not that small. I read other post where people tell that the grass clipping is so small that it's kind of magically disappearing. This is really not my case.
Can somebody with the mulching kit installed tell if it's normal to have to always clean the mower (and myself) after each use?
Thank you.
Just a few comments and observations about your mulching dillemma. Firstly, based upon looking at the pictures you provided, the first one(showing the tiny clippings that fly in the air and cover the deck), this may be evidence of a combination of using "mulching blades"...like Gator G6's that "pulverize the grass clippings PLUS the (A)mulch baffles installed underneath the deck not being the exact same "height" as the deck itself(i.e 4" deep deck and 3" baffles) and (B) the cutting height you have the deck set at versus the actual height of the uncut grass. Still on the same subject, let me elaborate on the "rules for mulching" as I understand them. First of all, when mulching it is important to "mow often" and not allow your grass to get too tall. Secondly, is that effective mulching is achieved at a MUCH slower speed than regular side-discharge mowing(to allow the mulching to effectively force the grass clippings back into the remaining cut grass)......and to not cut the grass too "short" so that there is not enough remaining grass to "absorb" the clippings(I would recommend nothing shorter than setting the deck at 2-2.5 inches). Thirdly, is the unspoken "1/3 rule" and that is "NEVER" cut more than 1/3 of the total height of the uncut grass(i.e. if the grass is 3" high and you set the deck at 2" you are cutting 1" of 3"tall grass.....or 1/3!!!). I would suggest that you try my suggestions and post back your results.
The remaining pictures you show(buildup grass clippings underneath the deck) can be several things including the amount of grass height you are cutting mentioned above(if you are cutting 2-3" off the grass and mulching it.....that's gonna be a LOT of clippings to be dealt with by the mulching kit and the fact you are not really "discharging" any of those clippings.....AND....a lot of your pictures indicate excessive "moisture" in the clumps of built-up clippings. It is a "cardinal sin", when mulching to have had any significant rain/dew/fog in the previous 48-72 hours and you really need to adjust your mowing schedule(and time of day...late afternoon will allow the sun to "dry out" the lawn from any overnight dew, etc.) to make absolutely certain the grass is nowhere close to "being wet"(this by far the MOST difficult thing to obtain and I think you will find that even following my recommendations in the first paragraph that inherently you will need to scrape the underside of your deck more often than if you did not have a mulch kit and were side-discharge mowing(that's just going to be one drawback of using a mulching kit).
All that being said.......I am by no means a "ZTR mulching expert" and there is some truth behind the argument that some ZTR's(especially the light duty residential models) just don't have what it takes(generally high torque engines and blade tip speeds in excess of 18,000fpm) to "effectively" be a really good mulching ZTR. In those cases(and this may apply to your particular mower) you are probably better off taking the mulch baffles off and simply running some Gator blades to cut the discharged clippings a little finer to decrease the windrows of clippings left(and after finishing mowing...if you raise the deck height 1/2 inch or so and mow back over the windrows several times this may sometimes disperse them where they are barely if at all noticable)...and if the clippings have any evidence of "moisture", let the sun "dry out" the windrows some before you try to mow back over them(wet clippings just simply won't disperse except in "clumps").
I hope you find this information beneficial and if you try some of my suggestions.....you MAY see an improvement to your dilemma......at least I hope so(I reserve the right to be wrong:0)
