djdicetn
- Sep 3, 2012
- 12
- 2,193
My mulchkit is nothing. It's just something that blocks the chute. I agree that the design doesn't seems to be really good but right now, it's doing an OK job of mulching. The flying grass and under deck clogging is probably a side effect of the poor design of the mulchkit but I can't says that for sure. The deck and mulchkit design have been change in 2012 on my model so it maybe be a new problem. This I mainly why I posted it here to try to see other user experiences with the same model but nobody with this model respond.
As for removing the mulchkit and installing gator blades, I would try it but I can't find the right size gator blade for my mower. It's 3 blades of 14.xx inches (i can't remember the exact size...).
Finally got a chance to post some pictures of my Gravely mulch kit. Check out the link below, and if your mulch kit isn't designed like mine(heavy gauge steel, fully encloses the blades and extends to the bottom of the deck edge), which you indicated that it is not, most likely your results won't be as good as mine are(mine works GREAT)!!! I hope you get your dilemma resolved and get a professional looking cut on your lawn which should be expected!!
http://www.lawnmowerforum.com/hustler-forum/20286-clogging-deck-2.html#post131312
