Repairs Ariens spindle
sclary
Would a tie rod fork work?
That was a very good video
sclary
Thanks for all of the help, all apart, now looking for parts!
Carscw
You can find the whole spindle complete with pulley for around $70
(( racing is the only sport that you need two balls ))
Talons06
If you have all the bolts out your going to have to pry it up. Put some bp blast on it tap it easy with a hammer then try and pry it up. If that don't work get a bigger hammer and screwdriver
You have to get the pulley off first. It can be a pain and you'll need gear pullers. After that you can remove the spindle. If it is busted, get a whole new assembly. They can be rebuilt, but you will need a good housing. You can get the bearings most anywhere.
Youtube has some good clips on it.
