New member, hoping to pick some brains.
My father-in-law was given an Ariens YT2548 tractor that needed some work. The guy that had it before beat the hell out of it.
Model #936036
Serial #000158.
After replacing the clutch, clutch anchor and some odds and ends, we fired it up to test it out. It kept throwing the belt, so after some investigation, I decided to change out the idler pulley assembly with all new parts. It was beyond wore out. However, it kept throwing the belt. So, back to the garage to troubleshoot. What I found was the jackshaft was destroyed. The bearings were all but gone and there was a pile of metal dust below the jackshaft on the plate, so I ordered all new parts from Jack's.
So, after all that rambling, I have a question. Is there a specific torque spec for the nut or just p.f.t.? I don't want premature bearing failure. Nobody likes anything premature...
Thanks,
Tim
Model #936036
Serial #000158.
Thanks,
Tim
