Patman68
- Aug 28, 2013
- Threads
- 4
- 20
Hello I done it again, I purchased another SNAPPER!!
Got an SR1433, from a local guy for $250 has a 15hp Kohler Command. Mower seems to be in good shape on the hole but does have a few tiny rust holes in the deck, Mostly under the belt guard. There is one problem though of which I do not seem to be able to figure out. The top part of the silver tag containing the Model number is torn off so I have no idea on the model number. The previous owner replaced the disc but I am not sure why it is rubbing against the lift yoke especially in 1st gear. I have tried adjusting the cable to the brake petal but that did not seem to help. Any ideas and how can I find a manual for mine without the model number. And how to fix the problem with the lift yoke.
Patman
Patman
