As Sols found out to his misfortune, oil aint oils. well leads aint leads aint leads.
The negative post will be 4% Sb the clamp will be 2% Sb, 0.5% Sn not vastly different alloys but different enough.
I don't see many lead terminals, most are brass or steel as the media who know nothing about metallurgy decided that all lead is the devis metal and any contact with it, even the sight of it will result in death.
The posative post is a different alloy by the way.
Next time you buy a new battery have a good look at the terminals and you will notice they are different colours.
One will be fairly shiny and tho other quite dull.
The + plates are made from a different alloy to the - plates and that carries on for the bus bars & terminal posts.
The mear act of doing up the bolt will cause a galvanic cell to be generated within the actual terminal itself.
But don't take my word, go to the battery university ( web site ) and read that.
It has a web page so it must be true :laughing:
