Add a fuel Filter? Yes or No?
GregGA
I've seen some small fuel filters that can be added to my Honda HRX. I think it would be of value. Does anyone use one, and which one? If it's not worth the small cost and effort, let me know your thoughts. Thank you.
Yes its cheap insurance.
I run in-line fuel filters on all my mowers like said above cheap insurance
Yes put one on. Everything should have a filter.
(( cowboy up and get over it ))
Most all commercial mowers, even the commercial push mowers all come with a fuel shut off and gas filter if that tells you anything. It would be worth the cost to install one.
Sold. Thanks guys!
Ya I buy mine through napa for a buck fifty takes 30 seconds to put in just cut the existing fuel line while still attached insert filter all done :)
Most Honda's mowers already have a filter ("fuel strainer"); just pull one clip and it is inline with the outflow fitting at the bottom of the fuel tank. Remove and clean or replace as necessary...
Those strainers are a pita.... I remove them and use an inline filter much easier
