markslawnservice@hotmail.
- Aug 31, 2020
- Threads
- 1
- 12
This mower starts and runs when cold. After its warmed up it will sputter and almost backfire and stall. When you go to restart it it will idle real low for 20 seconds then stall. When it cools off it will start and run good again for 15 minutes.
I have changed the gas, gas line, carb, spark plug, manifold, coil and flywheel. It still does it. Head gasket is probably the next step unless somebody knows anything else to check. Thanks for the help.
