The Push mower
- Aug 22, 2020
- 59
Engine Model: 31P777
531 hours on a 18.5 Intek running something terrible. Checked flywheel key and it is fine.Popping out of the carb is erratic in inconsistent just no rhythm to this. Next I plan to check the valve adjustment, but I have seen this same engine with a "flat" camshaft. Mower also has signs of hard cranking with a known good battery consistent with compression relief failure. Did have a missing screw in the throttle plate that I replaced today which did not solve the high erratic idle (carb cleaned and dipped in chem-dip and ultrasonic cleaner as well). Idle goes down to normal when I force idle down with governor arm. Governor arm is bouncing rapidly when engine is running. With spark plug removed engine turns over fine.
Wanting to get some opinions on this array of symptoms, before I tear into this thing any further. Appreciate any suggestions. Thanks.
