531 Hours- Popping out carb, running terrible, hard to crank.
Scrubcadet10
Moderator
Staff member
  • / 531 Hours- Popping out carb, running terrible, hard to crank.
Oh yeah, it was obvious. But I used a dial gauge when the engine was still assembled to avoid guess work. Then confirmed with calipers when the cam was removed.
This thing due for a DIY crank polish and a fresh rod bearing?
99.99% of modern small engines do not use rod bearings. just the crankshaft and the connecting rod.
The Push mower
I guess there is not much more to do than replace the cam and gaskets then...? Just trying to make a decent mower out of this one for my personal yard.
Scrubcadet10
Moderator
Staff member
Yep, cam, sump gasket, and PTO oil seal.
